Are these the same as the Ultrac Sessanta XL?
I've been searching high and low for my next set of tyres and the Vreds seem to be cropping up on every search.
I can get all 4 for £475 fully fitted (or £432 just delivered) from
http://www.tyretraders.com - how much did you pay and where if cheaper?
Also does it matter is one is a different speed rating to the other pair? I cannot find all 4 on the same speed rating, only:
VREDESTEIN 245/40ZR17 95Y Ultrac Ses...
VREDESTEIN 225/45ZR17 94Y Ultrac Ses...
I've been using Pilot Sport 1 tyres for the past 10k miles (they already came with the car with around 5~mm tread on each corner) and find them to be very good for grip in wet and dry.
They do have a harsher ride than I'd have hoped for but the corner handling (commute through most of the windy roads in and around the Southampton & Fareham area) and braking I found to be faultless.
They do tramline at lower speeds though!
I wouldn't mind them again (the PS2 though) but they're too expensive for what appears to be equal performance to other cheaper tyres and I'd rather have something a little more less harsh whilst still having the same grip and handling!
