RCA jack *2 (Front R / Front L), 6.30mm jack*1 (Headphone out)
The middle big 6.30mm is where you plug in your expensive headphones
The problem with front panel audio is you have to run a cable through all the EMI inside the case, this would very likely corrupt it immaculate audio quality you get by going straight in the back.
