not really, not everyone knows where he's gone, and a few probably don't know that he's left![]()
Do any of these cards accept a SPDIF cable connection from the motherboard to allow the audio signal to be carried through the DVI <> HDMI adapter so that the sound would be passed through to my Plasma TV's HDMI port..?
Also do they come with a DVI <> HDMI connector..?
At the moment my 4870 carries the HD audio signal directly through the DVI <> HDMI adapter to the TV without the need for such a separate cable.
But at least if I knew that they had a SPDIF connector on board and they could carry the sound signal to my TV then it would save having separate audio cables connected.
Whats with the "Graphics Plus" thingy in the components menu anyway?
Unless Nvidia decided to get the crayons out and play around again...
the cut off is 5pm i think for dispatching items
at least you can have a 280So I missed it by a mere minute. Sucks to be me![]()
yep, it'll also be better than my 6800Will this be better than my 4870 1gb?![]()
if only I could press buy...
hence the "if only I could"I think you would be the only one in the world to pair a GTX 280 with a P4
