Which Monitor?
11 Apr 2008
I have had most of them but still can't make up my mind. :confused: The cheaper unless it is really worth it.
Dell SP2309w
Dell S2409w
BenQ V2400W
BenQ G2400W
Acer G24
Samsung SM-2493HM
HP w2448hc
HP LP2475w
Hazro HZ24Wi
Which one from the list and is there any other good 22"-24" ones that I have missed?
personally I own an Acer G24, but mine has multiple issues at the moment, so I can't really give you a recommendation of weather its worth buying or not. When i get it fixed (or replaced) i'll post my thoughts :)
Thank's, I havent heard much about the G24 so that will be helpful. The only thing that puts me off about the G24 is the colour. What do you think about it? Maby you could put a pic up of it.
well thats what i use mine for. it does have backlight bleed but i only notice it on windows starting up. but thats me. others would get really annoyed with it and rightly so.
I currently have got the Dell SP2309w and that has a little bit of bleed at the bottom as well. I am going to get another on tho, as has got a little mark on that wont come off.
