I plan to get myself a E6600 Core 2 Quad, and notice that @ stock its 1066mhz, I was going to get myself some 2x2GB 800mhz OCZ stuff that is on offer at the moment, although if I put it straight in all at stock speed in my unit, would that mean that the RAM is overclocked already ?
As the RAM is running at 800mhz and the CPU at 1066mhz ?
Also i've heard about RAM ratio 1:1 and 1:2 ??
In regards to CPU, i get about the FSB is double your clock speed etc etc, although ...........
Could someone perhaps explain this please, as i understand 1:1 is where the RAM is running at the same speed as you CPU, and 1:2 is where your CPU is running at one speed, and your Ram ..... well ........ slower ?
Where would you find the RATIO anyway? at the moment i've got an old Asus Nforce 2 board, and i cannot see anything in the BIOS relating to that, apart from memory frequency and it going from 100% to 200 %
I do plan to OC my new kit when i get it, but would like to further understand the above points first ?
Thanks a bunch
Thanks a bunch
), it gets rubbish temperatures and is generally a bit poo. So until I got the AC Freezer, I took the Intel fan off and superglued a stock AMD one from my previous build to the Intel heatsink, temperatures came right down lol!
