140mm Filters + Antec 300 Fan Setup
3 Jun 2005
The South
Just a few questions -
1) Do 140mm fan filters exist? If so could someone point me into the direction of someone that stocks them, as i know OCuk doesn't sell them, nor do other well know shops/sites/auction sites.
2) Currently, i'm only using the 120mm exhaust fan on the Antec 300 (NF-P12 + Ultra-120 are directly behind the exhaust) and the 140mm (at the top) isn't used at all. If i was to the 140mm, is it best to blow air into the case or suck air out (ultra-120 is roughly 10mm below the 140mm)?
cheers for the help! :)
Due to forum rules we cant point you in the direction of competitors, but alternatively you could make a fan filter from a piece of stocking mesh (yep i know it sounds strange:D) regarding your top fan, this should be set to extract air from the case.:)
