How to lose the most weight in a single day?
Just put a minus sign in front of all your food, so instead of eating 12 eggs, eat -12 eggs, the more you eat the more you lose.
Yep as said a mix of laxatives and sauna.
The laxatives will clean you out of any solids and will take a lot of water with it, then the sauna will finish you off. (probably literally, as I doubt a body could cope with loosing that much water in a day)
have a prostrate biopsy.. might not loose you too much weight, but man doesn't it hurt when you're hunting pain killers in a house you arent' familiar with :(
or... catch the winter vomiting virus... and stand well back!
give blood, donate a kidney and liver, have a sex change, get liposuction, urinate and pap , cut of all you hair and wear no clothes.. all technically possible in 24 hours.
fastest way would to shed as much water as possible so as already pointed out, sauna in some kind of sweat suit/plastic wrap.
One other option no one has mentioned is Colonic Irrigation :)
I'd hate to! However it's easy enough to do.
You can have a colon massage which helps you do a big dump.
You can also dehydrate yourself.
Not eat.
Giving a pint of blood will help you lose about 1/2 a kilo (or 1.1lbs).
All this is very bad for you really and not to be advised well giving blood is fine. :)
Laxatives and don't eat anything with salt in it, salt makes the body retain water.
To lose 1 pound you have to use up 2500 calories so thats about a 40km run.
All in all you prob could lose 4 pounds that day - but that wont be body mass lost just fluids.
