Have a look at webbo's review on the patriot 2000mhz ram:
http://www.overclock3d.net/reviews.php?/memory/patriot_pc3-16000_viper_series_4gb_ddr3_kit/1
he did get it to 2100mhz but wasnt very stable aparantly!
lolI'm looking at LGA775 systems that use DDR3 which It seems can actually use up to 2GHz DDR3.if you are using an intel chipset i dont think its possible to get the memory to run at the full 2000
wow, if it can do 2000 at that voltage and timings, I wonder if you can OC it![]()
So which DDR3 would best suit the striker extreme 790?
Probably the patriot viper stuff that webbo tested!
You can get 2x2 gb Patriot Viper 1800mhz for £170ish, so you're paying £110 for 200mhz
I think I'm gonna settle on 1800mhz and just try to push it a bit further. Reviews seem to say 1870 is around the max.
