URGENT quick question
19 Nov 2008
Just fitting my Q9550 to my Asus P5Q Pro. When i start to push the level bar on the CPU socket down, I meet serious resistance. Is this normal? I don't want to crush my 275 quid chip.
They're supposed to be locked in tight, though double check you've matched it up properly so you're not bending any pins - that would be the end of your cpu
It's matched fine and is level. When the bracket rests on it the bracket isn't level. I guess it just needs locking nicely.
Locked in. Thanks. We'll see how it comes out later.
there should be some resistance but check you have the cpu in correctly else you seriously do some damage
MW
This is the part I hate most about building, everytime Im convinced Im going to break something with the pressure needed.
At least it's not the old socket A method of putting your heatsink on, where you needed to use a screw driver to lever the clasp on to the socket. I hated them so much, the amount of times I nearly slipped and gouged out my motherboard.
yeah, i hated installing these
i felt more comfortable installing waterblocks!
As an addon to this; the P5Q Mobo, the I/O shield has a foamy thing stuck to it. Is this supposed to be removed? I can't see what good it can do.
God dont remind me, I slipped off more than once on them, luckily never ruined a mobo.
I liked the early socket 775 (i think) where you had 4 spring loaded pillar type type things that you just pushed in.
Keep this foam pad on, its a new type of io shield that asus are using, i kept it on mine and have had no issues, least it does away with the little flexible strips you have to slide the connectors below.
Ah....well it's off now. I couldn't fit the mobo in whilst that pad was on.
Ah fun times. Before I knew what I was doing I remember buying a socket A HSF from a local independent IT store, not knowing it was for an Intel chip. Took it back when it didn't fit, they tried, levered the clasp, slipped and drove the screwdriver right through the MB :eek:
(Yes they paid for it)
