Agreed, I had a strange problem with my ATi 4850 in that I couldn't run vista, as soon as you install the drivers I got no signal on my monitor. Apparently it's a common fault with vista and certain monitors but ATi don't know of a fix for it.
marcus can i ask why you would like a GTX 280 as you have a 4870 x2 aswell have you had problems aswell?I had that problem i found just using a dvi to vga adaptor plugged in with out a vga lead plugged in solved my problem via DVI , highly tempted for a 280 though
what psu do you have?Can anyone confirm if the Gainward comes with the 6pin / 8pin PCI-e connectors asap please? Or will i need to buy those seperately. My PSU only has one 6pin at the moment!
all gtx 280 is stock cooling, apart from watercooling3 left now folk. Also I've just noticed that the Zotac AMP editions seems to have a ridiculous core OC, I wonder how they managed that stunt on what seems to be stock cooling...
I've never heard of Atrix psus before. How many amps does it have on the 12v rail?
Good luck in shifting those watercooled evga cards yewen![]()
They will sell.....
Gainward now gone!
