Considering you can get it for £319 from DV, i'd imagine you should be able to try and get it for around £250-260 from an educational establishment.
I remember when they first came out a few years ago and they were best part of £500, and one of our guys got it for £250. Best bet is to ask tutors at your uni whether or not they specialise in Focusrite equipment. If they do, your looking at up to 50% savings in come cases. (although dont get your hopes up!)
@Neoni: Glad you're impressed with it! The hardware takes a little while to get used to, but its up to you whether or not you prefer hardware or software interaction. I always use the hardware as you tend to focus your attention towards just listening and tweaking the settings, as opposed to using a mouse/tracker and sometimes being guided by whats on your screen as opposed to whats actually happening to the audio.
If you have the chance, test out a raw vocal track (if you have one) with the LA2A (just in default mode, not free) and just listen to how transparent the compression feels. You can easily compress -8dB or more and it doesnt at all sound processed, whereas with other compressors (1176, 670), the compression is noticably hard, and you can hear it. It's a great way of learning why each of the compressors emulated has the sound it does.
Here's the method of getting around the naming system:
http://www.gearslutz.com/board/musi...te-liquid-mix-emus-brought-you-st-peeder.html
Just pop them into your snapshots folder (i removed the installation ones as i dont use default presets), and so when you want a compressor, just go to load compressor snapshot and choose the real compressor name that you want to load. Then you just do the same for the EQ snapshots. (just dont load a complete snapshot of both compressor and EQ as the presets are individual)
Enjoy.
