Just to stick up for the "cleaning" brigade, I just paid £400 odd quid to get my breitling serviced/cleaned and to fix a condensation issue it had.. The results were amazing, it was like getting a brand new watch back!
Do you mean they cleaned the exterior to make it look like new? If not then surely a watch either works or doesn't, if it was to lose 1 second every hour then it's hardly the end of the world.
I would say it sounds like a scam, took my wifes watch to the local key cutting place the other day and they changed the battery in 2mins and charged £3 so having to send them off seems strange to me!
p.s. yes I have never owned a watch that cost over ~£80 so don't know if expensive watches need special equipment to change the battery.
didn't think you had had it that long![]()
and also got lesson in how unwaterproof this particular time piece is!
er, didn't someone tell you that when you bought it![]()
may not have been to yourself but someone on here bought a watch which was 30m waterproof and I explained that,as daft as it sounds, 30m is not enough for swimming
they really ought to redo the classification system so it is not as misleading
sold the Panerai a while back, do regret it though![]()
