Excel help required - please
Man of Honour
29 Mar 2003
Blurton
Here is a timesheet I'm working on - Timesheet
People log their stop and start times into the 3 columns and the total time is added on the right column.
I would now like to add up all the time in the pink column so it shows at the bottom.
I've tried a SUM command and I've tried a long winded method of +r7+r8 etc but I can't find a method that will add up that column correctly.
I can add 2 of them together but as soon as I try 3 or more the answer goes haywire.
At the moment there are only 4 figures to add up which should come to 32:45
Also in cell v47 I wanted to add a formula that would subtract v46 away from v45 and multiply it by 7.5 but I can't do that either.
Any suggestions?
Thanks
I think the problem you have is that the cell formats are a mix of 'number' and 'time'
Excel turns hours into 'days' when it puts the result in a 'number' formatted cell.
Try setting the format to the result cells as a custom date/time format of [hh]:mm and that should see you right (the []s make the hours wrap so that 1 day 4 hours is displayed as 28:00 which is what I am guessing you want).
Also watch multiplication/addition as 5 * 4:50 will be seen a 24 * 4:50 as 5 will be cast into time which will be 24 hours * 5
Here is an updated timesheet I'm working on - Timesheet
My problem is that I want to subtract y15 from w15 but as you can see one of them is a number and the other is the time [hh]:00
Is there any way of converting one or the other so that I can subtract them even if I use another cell to do it?
