8 Jan 2009 at 16:49 #1 zom247 zom247 Soldato Joined 29 Sep 2004 Posts 3,242 Location Wilt of the Shire Is it possible to play mov files in WMP 11? If so, do I just require a codec?
8 Jan 2009 at 16:51 #2 bledd bledd Don Joined 21 Oct 2002 Posts 46,851 Location Parts Unknown install quicktime alternative it's a freeware crap-free version of quicktime lets you view apple trailers and playback mov/3gp files
8 Jan 2009 at 16:51 #3 chaosophy chaosophy Associate Joined 3 Apr 2007 Posts 1,746 Location London Quicktime alternative should do, think the 'lite' version just gives you the codecs so you can play mov's in WMP.
8 Jan 2009 at 16:52 #4 Craig321 Craig321 Soldato Joined 2 May 2004 Posts 19,950 bledd. said: install quicktime alternative it's a freeware crap-free version of quicktime lets you view apple trailers and playback mov/3gp files Click to expand... This
8 Jan 2009 at 19:11 #5 zom247 zom247 Soldato OP Joined 29 Sep 2004 Posts 3,242 Location Wilt of the Shire I've installed this and WMP still wont play the files. I'll uninstall then re-install to see if that helps.
9 Jan 2009 at 08:48 #6 bledd bledd Don Joined 21 Oct 2002 Posts 46,851 Location Parts Unknown i don't use wmp, but it should work.. i use media player classic and that handles all mov's fine after installing QTA
9 Jan 2009 at 12:40 #7 lsg1r lsg1r Soldato Joined 25 Jan 2007 Posts 4,803 Location King's Lynn I've used quicktime lite (same as alternative minus media player classic) and once its set to open in wmp11 it worked fine.
