- 27 Jun 2008
Hello,
I am in the process of changing my case fans to sharkoon ones which are a lot quieter than these silly led things. I am Surprisingly still running my 350 watt psu with my ati4850 and I have had no problems at all with it over the last 7 months etc. However the fan in the psu is also very noisy so in regards to making my rig quiter I am thinking of replacing the psu to a new one which is quieter. This is where i need some advice as regards to which ones to go for. I don't want to spend more than £50 and cheaper the better so long as the fan is quiet. Also I am thinking of getting say a 650 watt psu. I know my 350 watt works fine but If I am going to upgrade the psu I might as well get a higher wattage. Any advice please.
My spec machine
Ati4850
Duo core E8400
4gig vista gold memory
gigabyte mobo p45 or something
My spec machine
Ati4850
Duo core E8400
