-== GTX 280 plummeting in price at OcUK! ==- LAST CHANCE!
Status
Not open for further replies.
Sorry if this has been asked etc. But when are the 285 due? How much will they be? Is it just worth picking up a cheap 280 if you have 250 max to spend.
Thanks.
Due next Thursday the 15th, also definately worth picking up a cheap 280 now, as thats all the 285 is, just higher clocked and on a smaller 55nm process.
says theres another 4 pov ones available...............still waiting on mine being shipped though:(
2 POV's now. :)
I wouldn't worry about it being shipped, as it should go today, you sometimes don't get the shipped e-mail till later on in the evening.
Thanks mate, just ordered one of the POV ones for 229.99 including which is a bargain tbf. Think its gone through etc as its now saying 2! :D
No worries, got an absolute bargain there. :D
Last POV's have now gone, as has the ASUS one from the B-Grade.
Boooo all the cheaper 280s are all gone. Only just the EVGA 280's left now and I doubt much can be done about those since they are the premium ones. Though we can only pray :D.
The purchase price for us has shot up dramatically guys so the price on these is going one way and one way only.
Will keep the price on the 280s we have left as low as possible for as long as possible but I cannot work miracles unfortunately.
Makes me wonder now who is gonna buy a 280 for £300 or more so. With the current stock levels surely they are going to come down again eventually or OC will be stuck with a load of stock they can't shift.
Hmm...will a Corsair HX520W be ok in handling this:
E8400 @ 4Ghz
Abit IP35-Pro XE
2x2Gb ReaperX HPC PC2-6400
2x 750Gb Spinpoint F1 Raid0
and the POV 280GTX?
Thanks a lot!
I was sitting on the floor next to my pc while running 3Dmark 06 and I heard a high pitched electronic noise coming from my pc during every introduction screen.
The noise happens as each intro screen fades in and again when it fades out but during the benchmark it is totally silent (other than the fan)...I've traced it to the GTX 280 and so far as I can tell it doesn't happen in anything else.
My PSU was bought last year, 750w Thermaltake and I've tried disconnecting any extra hard drives and things that don't need to be attached but the noise still happens so I think the PSU is fine.
Is this normal? :(
Is this normal? :(
Yeah its normal, its "capacitor whine" or some such thing. My 4870 does it sometimes, especially when using ATI Tool but when its on the floor and the speakers are blaring I don't notice it
I hope so, last time I heard a noise like that it was a failing PSU but this one is definitely coming from the GTX 280.
I've got till Monday to RMA it so if it's got a fault I hope it shows itself soon.
Status
