Spec me some ear plugs
I find the only thing that works is music...
Somehyow I can sleep with that, but not other noise.
Ypu can get custome fit ones which will do a better job, but they cost around £60, Just be carfull you don't get the ones which allow vocals through.
In my experience they don't work unfortunately :(
Not true, I sleep with earplugs due to having two house rabbits and two hamsters in my bedroom, and they suit me fine. The only problem theyve created is that I now cant sleep without them, so have to remember to take them everywhere with me.
I used to use my cowon plus my partners zen and the art of relaxation mp3 the sound of this was so much better than the noise from next door when i was on a 6am finish
Honesly, I recommend a pair of soft foam disposable ones. I tried some expensive ones re-usable ones and found them really uncomfortable. They don't cost very much, and if you rinse them you can re-use them once or twice.
Real alpha men don't use earplugs, they just go and nuke the source of the noise from orbit, and attack the ashes with their keyboard.
Ken is a wuss :(
Thing is everyone's ear canal is a different shape and what may be the dogs danglies for on may be next to useless for the next person.
I always wear earplugs on my motorbike and tried loads of different types before finding the one that worked the best and was mega comfy.
I even tried the custom ones moulded to your ear canal shape but they were uncomfortable so now I find the EarSoft ones the best for me.
How do you hear the alarm clock?
You just do, its right by my bed, and it wakes me up without fail. As Acidhell says though, when you get up at the same time every day, your pretty much awake before the clock anyway.
