Windows 7 beta - 9th January
Windows 7 Beta 32-bit and 64-bit Download Links.....
Hiya everyone,
The download links for the 32-bit and 64-bit Windows 7 beta are below:
Windows 7 Beta 64-bit
Note: If you click on the above links and it takes you straight to a Microsoft website, right click on either link, click on "Copy Shortcut" and then paste it into a new window.
Windows 7 Beta Key:
From having a read around, it would seem the keys won't be available till 3pm Eastern Time which is 8PM our time. I'm not entirely sure but I think either this page here or this one here where you go to receive your key. Be patient though since it may take a while for you to complete the process due to high traffic levels. Remember though, there are only 2.5 million keys available, according to Microsoft.
Source - Windows 7 public beta released
if you dont get a key you can always use the rearm trick on it open the command prompt and type slmgr /rearm then enter and you get another 30 days you can do this 3 times so you get 4 months to test it anyway
The download manager didn't work. It asked where to save the file to and added itself to the list but cancelled :(
Looks like there is almost no chance of me getting a key. "Server Busy" is all I get. All 2.5m keys must be spoken for by now.
Managed to get Messenger working at last! Had to disable the network auto-tuning feature...
Is there a way to get it to sit in the system tray? Taking up a huge space on the taskbar seems like a step back for me. I miss the small system tray icon :(
Yeah, I have been trying to figure it out for the last hour with no luck :confused:
Hang on a minute....
Did I hear right that beta keys for Vista do actually work with the Win7 beta? 'cause I already have one of those that I never activated way back.
