incase i missed it, is there a time limit on this beta key before it expires.
9th August.
https://www.microsoft.com/betaexperience/productkeys/win7-64/enus/default.aspx
I've been using that which was posted here a couple of hours ago.
By the way copy and paste it as clicking the link doesn't work you will probably get an error but patience is definately needed.
Done now. Can anyone recommend the best VM software to use this in?
virtual box
Thanks for your interest in the Windows 7 Beta. The volume has been phenomenal -- we’re in the process of adding more servers to handle the demand. We’re sorry for the delay and we’ll re-post the Beta as soon as we can ensure a quality download experience.
Just found out that if you have 1 or more hotmail accounts you can get spare keys
log into each one at a time then sign up to MSDN with each email addy
you just need a normal account not a paid one.
Then sign into MSN go here https://msdn.microsoft.com/en-gb/subscriptions/securedownloads/default.aspx
you should be signed in (if not do)
then open a webpage and past the link that Will Luck gave
and after a few F5s you will get a key.
You can get a key with each hotmail email account.
By the way my mate used CCleaner to clean out stuff after each MSN login..
