- 4 Oct 2007
I tried all that and have been opening masses of tabs still only to come up with the error:
Keep using F5, it took me an hour to get mine
hopefully i'll be able to get a key when the downloads are back up if not ill have to get it by other means :S
I dunno if any one has mentioned this, have a look around there is an AMD Windows 7 driver preview pack.Hmm, i'm having problems installing the 8.12 ati drivers. I installed them before, rebooted and when the pc came back online again W7 installed the generic built in drivers! Now when i'm trying to install the 8.12s again its just hanging on "Detecting basic system configuration". Anyone else experienced this?
Quick noob question here, does the Win7 installation menu let you set up a new partition or do you have to do this before you start installing?
I've never messed around with partitions before (always use a seperate physical disk) but at the moment i only have my os drive and a raid 1 array so i'm going to have to split the OS drive.
Keep trying, i just got mine after about 10 refreshes![]()
Like I have said more than once, from where I am it downloads a 717 byte iso.
