Now I just need to buy a case and put a comp together..
im getting no luck with ther refresh trick..damn, i dunno if i can be bothered anymore. i'll just crack the damn thing
W00t! got one.
Check4change is the key, only used it 5 mins.
Thanks a bunch to A[L]C for fist pointing to that.
you have to highlight text in the page
I highlight this:
The site is currently experiencing technical difficulties, please check back in the next business day.
as soon as the page no longer say that it alerts you
if you are getting redirected to the windows 7 page or the main MS page it's because you are not logged in.
if you are using 2 browsers you need to login in both of them so the cookie is there
Which URL did you use?
Where does one login?
