The fans on my GTX's dont spin up straight away, they usually kick in during post, does yours not spin at all?
Hi
i got similar problem please help see post POV 280 GTX
http://forums.overclockers.co.uk/showthread.php?t=17962727
My new POV 280 GTX just arrived so i pluged it and i get beeps one long and three short and the card led is red PLEASE HELP.
My system:
FX-55
Asus A8N Sli Deluxe
2GB OCZ gold
Samsung spinpoint 1TB
PSU OCZ 520W powerstream
thx
AFAIK PCIE 2.0 is backward compatible with PCIE 1.1 but not 1.0, could be wrong though.
lol seems a lot of these 280's that OCUK were sellin off cheap were ex bgrade or returns etc as theres a lot of threads with the bargain 280's havin probs.
Where are you in the country, you are welcome to test on my rig if you are close. Ive owned a POV too so know them...
Possibly a long shot but do you have any spare ram to test with? when building my new rig i used old ballistix 2gb kit and there was no display but hdd's span up etc. no post errors or anything.
Put in a new 4gb kid of ocz and all was fine! might be worth a try![]()
Its obviously graphics card related if its booting into windows fine but no display. It sounds like a lack of power tbh. Youve definitely got both of the power cables plugged in correctly? Have you tried a different monitor? Id try it in another machine if possible and if it does the same in that then try an RMA to POV as OCUK will only be able to offer a refund.
