Spec me a tripod
23 Oct 2006
Newcastle, The Toon
Hi. Im looking at getting a new tripod. I have around £130 to spend. Thats including the head. Id like one thats going to be rugged but also light. Cheers.
Something I'd like to know too. Having looked at e.g. Manfrotto, there seem to be a whole wealth of heads, three way heads, ball heads, gear heads and tripods, it's all a bit bewildering!
Obviously if you're sticking a huge, heavy lens(and camera) combo on it, then I guess you'd pay more?
As far as I'm concerned (not wishing to hijack your thread!) is something about the value above that is light and will support a 40D and zoom (300mm at most).
Cheers
Cheers
Yeah im pretty much after the same as you. D40x atm but may be upgrading next year. Need something light as i do a lot of Urban photography.
Have a look at redsnapper.
I've just bought one and for the price I am well impressed.
I was going to get a Manfrotto but it's supports 5kg whereas the Redsnapper supports 10kg.
Also, if you are member of talkphotography, Redsnapper will give you a 10% discount :)
Seconded. Get the ball head too :)
Let me know how you find it - both that and the Redsnapper mentioned earlier seem like the sort of thing I'm after.
First impressions. Its heavy. a lot heavier than i would have liked. but, this reflects on the quality. Its the BMW's of build quality. Materials feel very nice and well made. first impressions good!
Ha, wait 'til you try even an 055, never mind something sturdier. A 190 is not heavy :p
Bump of this thread because I really need to sort this out..
Recommendation for support of an Eos 40D
Probably go with Manfrotto as that name gets bandied around greatly but haven't a clue what head to go for.
I just thought that since Redsnapper import Velbons, and since they look identical in every picture...
Nah they're chinese re-brands IIRC ... I searched for a long time for where they were coming from when I was first looking at them.
They're superbly built and very sturdy. I've got one with the ball head (with the 10% discount) and I'd highly recommend it.
// EDIT // Been looking for a link but I can't find the one I did originally. It's much harder now, as all you get is redsnapper results. When I found it last time, there was a table with all the tripods in the range and a bit about them. It was definitely the one that redsnapper sell, but I can't think who makes it.
For the money you are looking to spend I would go for Redsnapper, they are very highly rated over on Talk Photography by people who get a lot of use out of them.
Sorry to hijack, have any redsnapper owners managed to get the head and the legs in the bag together? I've got the 3-way head and it won't go in the bag with it on :(
