My e8600 on air idles @ 19c in an Antec 1200
As matt100 said, not a chance in hell unless you're sitting in a walk-in fridge.
Actually mine is same whilst using OC, room is cool with window open but certainly not cold or uncomfortable, the 1200 has great airflow.
You clearly have no comprehension of physics or the evaporation process, think about it, if a fan blows on you you feel colder no? Theres no actual cooling within the fan going in its just the motion of air, same principal here
http://www.devicelink.com/mddi/archive/98/01/027.html
Heat sinks can be used with or without fans and offer considerable installation flexibility, but they cannot cool components below ambient temperature
http://www.scaleoutadvantage.techweb.com/news/fut_iweek20070108_Keep.jhtml
Elementary Computer Cooling Principles
Furthermore, since we cannot cool our system below ambient temperature
http://fray.slate.com/discuss/forums/post/2254931.aspx
The author of the article made a number of errors in his article and shows only a brief and flawed understanding of what wind chill is. Wind chill principly measures the effect of wind on evaporation on the human body. Any time a liquid is turned in to a gas a temperature drop occurs. Wind cannot cool objects below the ambient temperature unless there is moisture to evaporate
Not sure how much that applies to the thread starter's water question.
I wouldnt mind knowing what the peak temperature is.
My Reserator, cooling an AMD X2 4600 (90nm) and 4850 (stock) hits an absolute peak of 60 gaming (odd 61 showing in logs rarely). If its a prolonged gaming session and I exit to the desktop it will then idle around 55. It takes hours for it to go back down to the high 20's. If I start windows from cold it will be idling in the very high teens and take some time to reach the mid 20's.
I'm a little worried for the longevity of the pump with those peak temperatures.
snip
well for starters, unless you're pouring water over your heatsink nothing is actually evaporating.. there is a phase change happening inside the heatsink of a gas turning to a liquid and vice versa but no evaporation.
And trust me, I know exactly what i'm talking about thanks very much so there's no need for the atitude, I'm trying to do you a favour. You're talking about wind chill which is NOT cooling.
So your room has 0% humidity then does it? I doubt it, which means theres is moisture in the air which settles on the CPU/Heatsink which then evaporates
The core temperatures are not the same as the water temperature thankfully. The Zalmans can take a decent heat-load for a long time. The Eheim pump they use is very, very robust, especially in the Reserator 1 V1+ and 1 V2.
