LE32R8 i bought it dec 07
Yeah i no Why its not far of full HD
Get 2x for Quad SLi, a single 295 will cripple on that uber res.![]()
i disagree the gtx295 is not pointless, but it would be uber overkill on OP set up. a 1gb 4870 or gtx/260/280 will be fine and will be good enough if u upgrade cpu/mobo later down the line
The 295 as a graphics card is pointless, though you'd obviously disagree since you've bought one.
£100+ over the competition for what gain? To add even more hurt, the 4870X2 has just had its RRP slashed, so it'll make the 295 even more pointless.
You're throwing money away getting one because they're not supposed to last long. They'll be end-of-line in a 2 months and offer nothing over a 4870X2.
u should stick with single card suggestion 280gtx would me more thAn enough
