Nothing like heat straight to the old 'chap' though...
Unless you'd previously hiked 2 miles in the freezing cold why would he be so cold?
Why buy one without and then do a ***** modification when you can have the factory configuration with auto levelling for no conceivable extra money?
[TW]Fox;13279422 said:Auto levelling does NOT level the lights on the fly to account for changes in road conditions/bumps/etc. It is simply to account for the loading of the car, something you can quite easily do yourself when you load the car up by using the control in the cabin. The Z4 3.0i' will already have headlight washers.
He probably wants a facelift car with the better engine.Why do you want to spend so much, you could get a 2003 3.0 fully loaded for just over £10K
I'm pretty sure my lights auto level on the fly, the beam projection appears to change noticeably when the car varies in pitch.
You make it sound like there aren't any good examples with xenon headlights. There are loads out there. Better specced cars are more likely to have them and at the OP's budget, he can pretty much p[ick and choose any spec he wants. It's not like he's looking for a bottom of the barrell '03 car.
Is it worth £8,000 though? Especially with the new shape coming out very soon, it's just going to be an old shape Z4 like mine.
[TW]Fox;13279739 said:I wouldnt say the engine is a 'significant' improvement more a natural evolution of an already decent power unit. The improvements come in the same way they came from M52 to M54 - increased rev limit, leading to more power higher up the rev range but it's hardly night and day and shaves only 0.2 seconds off the 0-60 time.
Clearly its a superior engine but it's not £8000 superior and there is no 'significant' about it, IMO anyway.
The residual values for newer Z4's have been pretty horific, I can't see that getting any better with the new Z4 just around the corner!
Ouch!
