181.20 driver for Nvidia GF
Aint this already been posted?
Anyway i'm using the 185.20 BETA's. They have improved performance slightly over the 181.20's. They also have a funky new feature in the NV control panel called Ambient Occlusion. It only works with a handful of games for now, and you generally get a big performance hit.
I used 2 x XFX Nvidia GF9600GT XXX and enabled as SLi - so these driver add up new features:
Exciting New Features:
* Added support for GeForce GTX 295 and GeForce GTX 285
* Enables NVIDIA SLI technology on SLI-certified Intel X58-based motherboards with all SLI-certified GPUs.
* Enables NVIDIA SLI Multi-monitor support, giving you the ability to use two monitors with your GeForce graphics cards in SLI mode. Now you can easily switch between multi-monitor desktop mode and full screen 3D gaming mode. Learn more here.
* Enables NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here. (Note: GPU PhysX is supported on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory. This driver package automatically installs PhysX System Software version 8.10.13).
* Supports GeForce Plus Power Pack #2. Download these free PhysX and CUDA applications now!
* Added support for the new NVIDIA CUDA Video Encoder with H.264 optimization
Blazing Fast Performance:
* Boosts performance in numerous 3D applications. The following are some examples of improvements measured with Release 180 drivers vs. Release 178 drivers (results will vary depending on your GPU, system configuration, and game settings):
o Up to 10% performance increase in 3DMark Vantage (performance preset)
o Up to 13% performance increase in Assassin's Creed
o Up to 13% performance increase in BioShock
o Up to 15% performance increase in Company of Heroes: Opposing Fronts
o Up to 10% performance increase in Crysis Warhead
o Up to 25% performance increase in Devil May Cry 4
o Up to 38% performance increase in Far Cry 2
o Up to 18% performance increase in Race Driver: GRID
o Up to 80% performance increase in Lost Planet: Colonies
o Up to 18% performance increase in World of Conflict
And More:
* Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, and OpenGL, including 3-way and Quad SLI technology.
* Supports CUDA.
* Supports Folding@home distributing computing application. Download the high performance client for NVIDIA GPUs here and join the NVIDIA team: #131015.
* Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
* Includes numerous 3D application compatibility fixes. Please read the release notes for more information on product support, features, driver fixes and known compatibility issues.
* Users without US English operating systems can select their language and download the International driver here.
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 260
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 9600 GT
GeForce 9600 GSO
GeForce 9500 GT
GeForce 9500 GS
GeForce 9400 GT
GeForce 9400
GeForce 9300 GS
GeForce 9300 GE
GeForce 9300
GeForce 9200
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS 512
GeForce 8800 GTS
GeForce 8800 GT
GeForce 8800 GS
GeForce 8600 GTS
GeForce 8600 GT
GeForce 8600 GS
GeForce 8500 GT
GeForce 8400 SE
GeForce 8400 GS
GeForce 8400
GeForce 8300 GS
GeForce 8300
GeForce 8200
GeForce 8100 / nForce 720a
GeForce 7950 GX2
GeForce 7950 GT
GeForce 7900 GTX
GeForce 7900 GT/GTO
GeForce 7900 GS
GeForce 7800 SLI
GeForce 7800 GTX
GeForce 7800 GT
GeForce 7800 GS
GeForce 7650 GS
GeForce 7600 GT
GeForce 7600 GS
GeForce 7600 LE
GeForce 7500 LE
GeForce 7350 LE
GeForce 7300 SE
GeForce 7300 LE
GeForce 7300 GT
GeForce 7300 GS
GeForce 7200 GS
GeForce 7100 GS
GeForce 7150 / NVIDIA nForce 630i
GeForce 7100 / NVIDIA nForce 630i
GeForce 7100 / NVIDIA nForce 620i
GeForce 7050 / NVIDIA nForce 630i
GeForce 7050 / NVIDIA nForce 610i
GeForce 7050 PV / NVIDIA nForce 630a
GeForce 7025 / NVIDIA nForce 630a
GeForce 6800 XT
GeForce 6800 XE
GeForce 6800 Ultra
GeForce 6800 Series GPU
GeForce 6800 LE
GeForce 6800 GT
GeForce 6800 GS/XT
GeForce 6800 GS
GeForce 6800
GeForce 6700 XL
GeForce 6610 XL
GeForce 6600 VE
GeForce 6600 LE
GeForce 6600 GT
GeForce 6600
GeForce 6500
GeForce 6250
GeForce 6200SE TurboCache™
GeForce 6200 TurboCache™
GeForce 6200 LE
GeForce 6200 A-LE
GeForce 6200
GeForce 6150SE nForce 430
GeForce 6150 LE
GeForce 6150
GeForce 6100 nForce 420
GeForce 6100 nForce 405
GeForce 6100 nForce 400
GeForce 6100
How do you get on with the 185.20? when I looked at them there was some performance issues and incomplete features "under the bonnet" due to being a rushed out beta to test a couple of things and not worth using for day to day.
These cause Fallout 3 to CTD on Vista. Going to have to roll back to the 180.48 drivers I think. Everything else seems to work fine though.
the 185.20s do not allow me to run farcry 2 in 1920*1080 so i binned them,they only went upto 1680...
i never use nvidia official drivers i always use the "tweaked drivers" from www.tweakforce.com...have been since 2005 but there site is down so i cant get there drivers
They seem to work ok for me, tried many many games with them. Performance is basically the same as the 181's but i get a little higher score in 3Dmark Vantage.
They also have 32xAA option :cool: you need a dual GPU card or SLI for it to be available though. I can run some older Source games and Painkiller with 32xAA + 16xAF @ 2560x1600 on the 295, the image quality is very impressive.
Yeah that's a temporary fix for now. Looks like the profile for it is somehow not working properly (had trouble using AA and AF on CP too.). I also had a mess about with falloutprefs but only fixed the problem for a few minutes max, then crashed again.
