I have ordered the supersprint manifold ( £330
), so that should be here soon. Also got a take off plate for the oil filter so i can fit my oil temp and pressure gauge senders. My old engine had the sender in the sump for the temperature, but i dont fancy drilling this sump! Tips on keeping it in good condition? I've had a stainless steel supersprint manifold before, and wrapping it from port to end in exhaust wrap did it no favours.
This one will need to be wrapped for part of it, to prevent it from damaging surrounding waterpipes / wires / radiator.
Is there anything i can spray on it first to protect it from moisture? By the looks of my old manifold, it was moisture retained by the wrap that damaged it.
