The All New Desktop Thread, Images No Larger Than 800x600
thats the first place i tried as i knew thats where i got it. Was pretty sure the one posted earlier was the xp version.
On a side note does any one else have a problem with deviantart not displaying all the results like only showing few pages when you know the should be more?
Windows 7, backup PC: Dell 755 USFF, E6600, 2GB XMS2, 1.5TB
i use the backup more then my main rig coz its always broke (currently web flash plugin not working and SSD's being a FU@:D)
Thats for Vista, I've not tried it though, then goto deviantart and search for vista themes, should bring up a load.
I saw a really good Vista theme the other day, I'll post it when I find it again.
Search for Vistaglazz, I think that patches the files for you.
http://www.winmatrix.com/forums/index.php?showtopic=11742
EDIT: http://vathanx.deviantart.com/art/NEXTLevel-71347045
Trying to install this - http://vathanx.deviantart.com/art/NEXTLevel-71347045
I done this Next unpack 'NEXTLevel' folder to 'C:\Windows\Resources\Themes' (where C is the partition with Windows installed)
but cant seem to change the theme via 'Control Panel\Appearance and Personalization\Personalization\Window Color and Appearance'
Do you know why? :confused:
Have you used vistaglazz to patch the theme files? I don't have vista but with xp you use a uxtheme patcher which then allows you to use other themes.
The following should help you out. :)
http://www.intowindows.com/how-to-install-third-party-themes-in-vista-2/
http://www.codegazer.com/vistaglazz.htm
