quick question on Fantastico Autoinstall
31 Oct 2005
Leeds
Hi there, very quick question
I usually just install the script I'm using to a directory
But now I have a lot of scripts I wish to install
Therefore I want to install to
Mywebserver / OPENSOURCE / Scripts
Now when fantastico asks where would I like to install
Inputting
/opensource/scripthere
or
Brings an error message, whereas of course
Scriptshere works fine
Help!
You'll probably need the path where your files are on the server, i.e.:
/path/to/your/wwwroot/opensource/scripthere
Cpanel should list it on the left somewhere.
Cpanel lists the Home Directory
/home/irgscouk
I tried /home/irgscouk/opensource/here
and
No luck
hmm might just be easier to manual install
Are folders 'opensource' and 'here' there, and have you set their perrmissions properly?
Also try with a trailing forward slash:
/home/irgscouk/opensource/here/
And post the error so we know what the issue is :p.
firstly Fantastico is stressing that the directory nor permissions must not exist
It says
Install in directory
Leave empty to install in the root directory of the domain (access example: http://domain/).
Enter only the directory name to install in a directory (for http://domain/name/ enter name only). This directory SHOULD NOT exist, it will be automatically created!
and
so I've now tried
/home/irgscouk/public_html/opensource/here
and
With and without the leading slashes
My error report
The installation can not be completed:
- No valid directory name provided.
Funnilly enough I'm currently studying linux and it's filestructure :D
Strange - opensource/Scripts should be fine. You should be able to install it in Scripts then ask your host to move it to the opensource directory (I know they will ;)) :)
might ask the host
It seems a well documented flaw according to google
That only workaround seems to be creating a website subdirectory i.e opensource.mywebsite.co.uk
Then choosing the sub directory in fantastico
Thats why I got chuffed off with Fantastico and went down the Installatron route - works with both cPanel and Directadmin (and Plesk?) and my world of Fantastico pain has been left way way behind :)
