I love these cars; I think everything about them is great. And no I haven’t driven one as of yet. I want to know your experience of one and really any information you can offer about them before I even start looking into buying.
The sorts of questions I have about them are as follows (but not limited to, any advice would be great)-
Running costs-
Thanks for your time, Eddie
- When was there a face life if any, I’ve worked out my self that it must have been around 2003/4? How could I tell the new model apart?
- What’s the difference between the two and is the newer model far superior? My budget isn’t massive what would a decent pre and/or post face lift ST cost me, please note MUST be blue!
- What was the standard kit on the both of them and what are the main options that one shouldn’t do without?
- I’ve got no problems with a higher mileage car but would that be wise with this car? I know Mondeo’s generally go for ever but I wasn’t sure if that would be the case with the ST?
Running costs-
- I don’t care that it will do less than 30 MPG, actually it’s a bit of a turn on, also I don’t care about road tax, it’s the “unknown surprises” that I’m far more bothered about. How often are these likely to pop up and cost to put right or are they generally quite reliable?
- What are the service intervals and how much will it set me back?
