Timing belt change intervals
10 Aug 2003
London
Does anyone know what intervals (at what mileage) the timing belt should be changed on a mitsubishi carisma. Mine is currently on 128K miles. I think it was last done at roughily 80 or 67K miles.
Thanks in advance guys :)
Does anyone know what intervals (at what mileage) the timing belt should be changed on a mitsubishi carisma. Mine is currently on 128K miles. I think I was last done at roughily 80 or 67K miles.
if it was done at 67k, that suggest that they last about 67k miles, so wouldnt be any harm in changing it when you get close to 134k. :)
utter lies anyway, engines die at 100k.
I had it changed.. at either 67 or 80K miles can't remember which. I have had the car since it was on something like 58K miles.
