its for an 05 fiesta 1.4 petrol. its due an oil change, it was 5w30 fully synth as far as im aware (im not that clued up on fords..)
being a girls car itll be driven with no mechanical sympathy ever so i want at least a good oil to be going in. any other fords knowledgables got anything to say about this oil wise?
ive got this to go in the sump
Fuchs Titan XTR 5w30
http://www.opieoils.co.uk/p-991-fuc...rmance-fuel-economy-synthetic-engine-oil.aspx
TITAN XTR 5W/30 combines a synthetic base oil with the latest and highest performance inhibitors available. Detergent, dispersant, oxidation and corrosion inhibitors and friction modifiers are incorporated to give excellent performance in many modern gasoline and small diesel engines.
TITAN XTR 5W/30 is recommended for all applications where SAE 5W/30 engine oil of ACEA A1/B1, ACEA A5/B5 and/or API SJ/SL/CF is specified. It is particularly suitable for use in the latest Ford gasoline and diesel engines where this type of oil gives maximum fuel economy and engine durability.
ACEA A5, B5
API SL/CF
Ford WSS-M2C 913B
ACEA A5, B5
API SL/CF
Ford WSS-M2C 913B
