asus bios flash
22 Sep 2006
London
i just upped my board from the 1406 to their new 1702, ocing just wont work with this bios. just crashs on xp load!!
how do i revert back to 1406? ez flash just says its older and wont use it.
not before, but it set everything to default... when i re-entered, things didnt work, reset to default and tried again...
its fine on default, but my OC settings and others i try just wont boot
I'm using 1702 and it's clocking great...your problem is that you loaded a profile from an older bios. Never do this. Set to default settings and enter all the settings fresh.
i have tried from scratch, no different
NOOOO dont use asus update!!!! download a older bios from the asus website and flash
thats the problem! ez flash wont let me go back...
i dont get it then. i tried the modded too. doesnt boot into windows when using the same settings as 1406 (manually set not oc profile) just bsod when windows loading logo comes up...
it cant be because of that because 1406 worked fine. exactly the same way..
i did reset anyway.
unless you mean pushing th ebutton on the board?
