rubber trim?! Where?
16 Nov 2005
Torquay
Im in the middle of doing a side window on my case, ive cut the hole and im trying to find some black trim to go around the hole.
Ive seen many people on here have done that, but for the life of me and i cant seem to find any?! Ive tryed looking in b&q with no joy can you help?
thanks
There is plenty of Water cooling sites out there that sell this.
search for "Blow Hole Trim"
I've just ordered 1m of this stuff. I found it under neoprene rubber edge trim. How is the window going, I've ordered it to do exactly the same thing, but as I'm only 15 I am kind of petrified of cutting into my nice case and an error will be expensive.
Got any tips? How easy was the cutting part.
Also what did you do when cutting it - low tack tape, mark out, pilot hole (drill), then cut with jigsaw?
Cuttings not hard.
I mark the area with a felt pen, make sure the side/case is seated, so that it cannot move. Drill some small pilot holes and then cut out the shape with a Dremmel tool.
Thanks for the help guys.
neon.uk - I made a template then used a router to cut the hole.
But as already said, you can use dremmel tools, jigsaws etc.. :)
I will upload some pics in the next few days, this is my first project. Got myself a lian li v1110b and ive mounted the rad at the bottom of the case and made the window. Just got to try and sort out the cable management !!
