antec 900 oe 1200
10 Jan 2009
London
is the antec 1200 really worth the extra £60 over the antec 900.
is their greater improvements in the 1200 than the 900?
which would you recommend?
Thanks
sorry for thread title 'or'
If you want more space, awesome air flow aswell as great cable management then get the 1200, the 900 MKII is just the same old 900 with a new skin.
i haven't experience with the 900, but I've got the 1200, and all I can say is "Bloody brilliant case." Bags of room, although, in my opinion, the stock fans are a bit noisy, even at the lowest setting, and the blue leds are a pain because you can't switch the front ones off. Which makes it annoying if the case is in your bedroom, and you want to sleep and leave your pc defragging. But that's just me...
