this has nothing to do with AS physics, its a matter of geography.
so if i correct people that are wrong i am a troll?
I thought you were stating that when water heated up it expanded, as someone else did.
No, you are a troll because you make replies in a way that riles people up needlessly.
There is no underwater ice apart from that which is pushed down by the ice on top of the water. It doesn't stay at the bottom of the sea you know it floats so you theory is void.
There is ice that is under water, it is under other ice. If for SOME REASON the ice under the water, and not the ice above the water, melted, the sea level would drop. I KNOW it is not possible and it will not happen, but it is still the case.
