The computer is quiet-ish, but there's still a very audible whoosh of air coming from it.
My machine:
AM2 X2 4200 (@2.8ghz) - Noctua 12cm cooler - basically silent, I don't think this is the problem.
Temps are excellent, about 30C idle and rarely above 40C at load.
Powercolour Radeon HD4850 PCS edition. This is rather quiet, though the small fan does create a higher sound that cuts through the other fans.
Akasa greenpower 500w PSU. This might be a culprit. It seems to create quite a lot of noise in the little cage that comes with the case. I'm wondering if it would be worth replacing it with a fanless PSU (I'll find a use for the old one in another machine). The bottom 12cm fan between the PSU and hard drives would generate enough air for that, surely?
Fans:
I didn't plug in the top exhaust fan because I don't think I need it. The back outlet fan is on, and it's a tricool. The bottom fan is on because I want it to take air past my hard drives. I initially had an optional fan in the middle hard drive cage, but it was too noisy, which surprised me because it was a Scythe that is usually rather quiet. Might've been vibration from the cage thing.
I'm considering a fan controller that is a bit more useful than the antec 3 power one. And would it be worth replacing the tricools, if so, what with?
Any recommendations are appreciated. Budget is hopefully under £100, but we know how these things are.
Cheers.
My machine:
Fans:
Cheers.
