- 16 May 2004
- Derby
You wouldnt be able to see Jupiter due to the fact it sits infront of the sun and sets below the horizon at 4:39 this afternoon. Pretty much same time as the Sun
Quote: Planet Venus dominates evening skies, shining brilliantly after sunset. The next bright planet to appear is Saturn, rising late in the evening in Leo. However, it is only half as bright as it would normally be because the famous rings which usually reflect so much sunlight, are turned edge-on to us. This also means that Saturn may look disappointing to users of small telescopes.
Also see: http://www.jodrellbank.manchester.ac.uk/astronomy/nightsky/
So I might be right thenVenus is the uber bright one... Saturn is the next obvious bright object?
If it is seen in the East it will be Saturn.
Aren't you forgetting that great big ball of mavity 'controlled' nuclear fusion known as The Sun?
Venus was the brightest object in the night sky tonight. Apart from the moon that is. Its something like 6 times brighter than Sirius. It doesn't appear to move in relation to the other stars either, at least not in one night.
At the time I posted I was observing Sirius, it couldn't have been Venus as it was below the horizon, I think there's been some confusion because of different times observing.
But yeah its a great time of year for observing Venus, its low in the S SW horizon, but as usual its completely clouded over now.![]()
Space Station?
Open up the "mini-astroviewer". Set the location to the UK, and time to 5pm today, and voila! There is Venus about 30 degrees about the southern horizon as I describedIt the brightest object in the sky by far....
Of course it is Venus, why don’t you take up astronomy?![]()
Did it to a small degree in my youth...
Given up here, too much light pollution
