simple jquery problem - creating and calling functions
12 Feb 2006
Surrey
this is seriously simple i know i just can't seem to do it, perhaps it's because it's late i don't know but i'm hoping when i get up someone can give me the nice and easy solution so i can get on with my work.
i want to create a function and then be able to call it from a timer.
i tried
PHP:
change1(function(){
// do cool jquery amazing stuff
didn't work :(
just in case it makes a difference what i'm trying to do is have 3 functions (change1,change2,change3) running one at a time. change1 checks if there is an element with id1, if yes do effect, wait a bit of time, then run change2, if id1 doesn't exist just do change2 straight away. change2 does same, checks, moves onto change3, which restarts again.
Isnt it;
PHP:
$(document).ready(function (change1) {
// do stuff here
OR
PHP:
// do stuff here
Code:
function change1(){
    // Cool jQuery stuff
and to set on timer...
Code:
$(document).ready(function(){
    setTimeout(change1(), 5000);
Something like the following to chain them. Prob an easier and neater way using jquery though.
Code:
$(document).ready( function()
    setTimeout(change1(), //timevalue in ms));
function change1()
    if (//id exists//)
        setTimeout(change2(),//timeval in ms//)
    else
        change2()
function change2()
    if (//id exists//)
        setTimeout(change3(),//timeval in ms//)
    else
        change3()
function change3()
edit- beaten :(
ah silly me that got it working, well almost.
the above is basically exaclty what i have just with the jquery stuff in it. the trouble is i get the following error: "missing ) after argument list" it says this for the line function change1() {
any clues why?
sorry, i missed the closing bracket round the $(document).ready( function()
should be
Code:
$(document).ready(
    function()
should be
Code:
$(document).ready(
    function()
i tried this but now the fade effect doesn't work, only when in the document.ready(, however the script still does the result if that makes sense. e.g. i want to fade between text, rather then fading it just changes to text.
I put too many brackets in that - might be why. Do you know you can debug javascript in firefox in the error console. Would have picked that up straight away.
Code:
$(document).ready(
    function()
        setTimeout(change1(), //timevalue in ms);
this is my problem ladforce, not the bracket problem you have said about.
i think i have realised the problem any way so thank you all for the help :)
