Haven't seen this posted yet so here you go....
Explains the dramatic Phenom II cuts !
http://www.extremetech.com/article2/0,2845,2339203,00.asp
AD
For example, Intel's fastest Q9650 (3.0-GHz, 12 Mbytes L2 cache) is now priced at $316, down 40 percent from $530. That means that Intel's Q9550s, a 2.83-GHz chip with 12-Mbytes of cache, is now a more expensive $369. The Q9550s, however, is also rated at a lower-power 65 watts, rather than the 95-watt envelope that the Q9650 uses, or the Q9550, which also received a more modest 16 percent cut to $266.
AD
