http://www.wiperblades.co.uk/
I've used them a couple of times. No problem with the service or prices although I'm not keen on Bosch blades. I'm sure others will have a different opinion though :)
I've got these on my e36 325i.
Not sure on the quality yet as I've not used the car much since fitting.
They certainly felt and looked decent enough though.
Go test it and let me know before I click buy ! :p
Used them before on recommendation from here and the service and product were very good
They've just had a run on today, due to this post :p Just ordered myself a full set (front and rear) after Halfrauds have decided they are "special order" only for a mk4 Golf :confused:
OCUK should ask for commission, thanks for the post recommendation.
I bought some of the Valeo flat blades from them, thinking about it that was ages ago and they're still working fine.
EDIT: But yes, no problems with the service.
I'd also recommend tha Valeo's as most of the time car manufacturers put these on cars yet rebrand them as their own.
