- 8 Oct 2006
Hey,
I live in a uni accomodation with 8 guys, who have a mixture of wired and wireless computers. I also have an XBOX 360, connected with a cable.
Initially we had a Belkin Wireless G plus box for our 2 meg connection, which had another 8-way hub connected to it, to serve each room in the house (we have one ethernet port per bedroom).
It wasn't the best router in the world, but it was a nice little workhorse - then one day recently I brought an XBox 360 .
At first I constantly switched the ethernet cable between my PC and Xbox, and both worked perfectly fine, but being the impatient chap I am, I decided to buy a wired router so I could have both at once.
This didn't work straight away, and I couldn't get into my main router's login for some reason.. So being the impatient chap I am, I hit router reset.
The button snapped.
I then opened it up to fix it, and the power supply snapped off the board.
I told my landlord what happened, and he kindly gave us a new router made by 'Tenda', which is, unfortunately, appalling.
- Has anyone heard of this cheap knock-off brand?
It's a W302 model, and I have been playing with everything - MTU settings, and DNZ and it gets worse and worse, the internet is dying, the XBOX is too slow to play online and my housemates hate me for their rubbish wireless signal.
- What DSL router shall I order from OcUK RIGHT NOW to make everything better?
If you really have useful advice for my 'Tenda', or you can confirm that they are as bad as I think then thanks, but please don't try and talk me out of replacing it, as for the sake of £40 I'd rather have a decent router that I can take home at summer.
My main criteria are that it should be:
- Around £40 (unless you can convince me one is really worth a little more).
- GREAT for XBOX 360.
- Can handle lots of traffic (8 way hub run into it).
- Good wireless range (our last was G plus, does this one need to be?).
- N technology seems a waste, as none of us have compatible hardware.
These are two models that have caught my eye so far: One is designed for gaming, and one seems to be beloved for its 'Tomato' firmware.
http://www.overclockers.co.uk/showproduct.php?prodid=NW-093-LS&groupid=46&catid=1014&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=NW-052-LS&groupid=46&catid=1014&subcat=
As soon as I have some good suggestions I'm placing an order, so quick responses would be appreciated - I would like it by Friday!
Thanks Very Much,
Alex
The button snapped.
Thanks Very Much,
Alex
