Q6600 - a bit too hot
Ahh, those sodding AC7 push pins. I was terrified I was going to break my motherboard but I got it seated correctly in the end, after much cursing and struggling.
Then I realised I had fitted it oriented the wrong way, so that the fan was blowing towards the front of my case ;-;.
I have done that before on a different build. I got it perfect as well then realised it was on backwards
So what can I push the temps up to safely?
I edged up to 2.8 and the temps all increased by 2
Were 42,42,36,36
Now 44,44,38,38
Still stock volts
Is 50 too high as idle?
you can go as high as 100 at 100% load but do remember that real life temps will never reach as high as when stress testing
So the max temp I can go to will be 100degrees?
So if I increase mine to 3.6ghz which apparently this chip can do then if its about 50-55degrees on idle, 60-65 on stress I should be ok?
perfectly fine yes, though i reckon max temps will be mid 70's not 60's just due to the general overall heat up of the cpu as a whole form all four cores being so close together
100c is the supposed Tj Max i.e. where the CPU will throtal... this is "safe" within the intel specified vcore range and at stock clocks... however if you are overclocking i would suggest you keep it below 75c on prime95 small fft load
long as the cpu doesnt throttle its safe so you can go right up to tj max and be safe
I dont think I would be completely happy running at 100c but mid 60s would be ok on load.
Now to try out a few tests.
Whats the best app for testing. I used to use sp2004 (I think it was called)
check that your HSF is seated correctly.
Also ensure your CPU its not being over-volted in the bios, some boards to that, aka p5nt
If 100c is ok why did Evilone say that I would get fried chips at 80c?
Cause he lied to you :p miss informed? personally wouldn't be happy with his cpu that high?
admittedly your temps are higher than they should be, unless of course it was the stock hsf which it isnt, but its really nothing to be concerned about unless obviously you are hitting over the mid 90's when oc'ing
Well im ok now, as im down into the low 40's
when lots of us were overclocking these chips the consensus was 70C under full prime load was the safe level to go too. There was a massive thread on q6600 overclocking on this forum.
Idle temps don't really tell you much tbh you need to look at temps when the CPU is under 100% load. I think you will also find the jumps in MHz become smaller the further you push the chip whilst the temprature rises become larger (C per MHz). Try it at 3.6 but don't be supprised if it's unstable and/or very hot.
I've got artic 7 fitted and pushed mine up to 3.4ghz couple days ago and seems to be settling at around 65degC under torture tests. So far no stability issues and it hasn't melted. I haven't looked at optimised the voltages yet as I still have it on mobo auto (which seems to be very good actually).
Tried sneaking up to 3.6 but it crashes at windows. I suspect this may be my slow ram falling over though.
Depends on your mobo but I've been quite happy with C1E and EIST on mine. Means that for most of the time it's throttling back to 2.2ghz and runs nice and quite and cool.
At full load with IBT which passed the test
It runs at 73,73,62,62 (these were the max temps)
Thats at 3.2ghz
Is that pushing it?
This is by running the volts at 1.2 (so with a decent cooler should easily be able to do more)
Edit: Strange but my idle temps have now dropped to: 40,40,34,34
