Permabanned
- 15 Dec 2008
Had the the radiator hanging off the back when i first got it, then i moved it on top over the massive 200mm fan thats on top of the Antec 900 case.
And today i finally moved it as it looked ugly as hell with tubes hanging all over the place...anyway...here it is
The case with the fans and fronts removed
The radiator in question
Fitted the first fan into position ready to mark up radiator for glueing
The radiator behind the fan, the rad fits perfectly in between the little tabs that support the dvd drives...perfect glueing ponits
The glue gun ( Still cant get over how strong the glue actually is
All glued in
Front plates and fans put back in
A view from inside
Looks better no???
Anyone know were i can get another 2 of those blue LED, 3 speed Antec fans from??
Just below the Blu-Ray drive there is a empty 5.25 inch bay, ive reverse mounted my HDD in there with an adaptor and because its reverse mounted you cant see the cables
All glued in
A view from inside
Looks better no???
