would put my bottom dollar on it having nothing to do with the card
with the right voltages on the nb and memory start turning powerplay back on and clock the card back up, see if you can narrow down exactly where the trouble lies.
why do these things always have to be so difficult? I wonder if anybody else with this same board has similar issues? could you try running with 4gb? If stability returns you can almost be sure that its a voltage issue.
Edit : when i say stability I mean gfx stability![]()
**** sake, its just gone back to error, error, error, error again.![]()
Have you tried the card in another PC or know anyone who you could pop round to test it on their pc.
Yeah, I've had it in 3 other PC's recently, on one it does the same as my machine, on the two others its fine.![]()
What are the specs of those machines? There has to be something different between the ones which it works in and the one that it doesn't, something has to be making it all go belly up.
