4870 - dual monitor query
12 Jul 2008
Does ATI have problems with dual monitor display these days?
I'm very tempted by the 1GB Sapphire 4870 but need it to run a pair of 24" monitors (1920x1200) in 'extended desktop' mode with no problems... I multibox WoW and will be running 1 client on the first monitor and multiple clients on the second monitor.
A bit of googling has thrown up many threads/comments from people having problems with dual monitors but not explaining their issue or seeming to resolve the problems.
Naturally, I'm a bit concerned. Particularly when the bottom comment on the OcUK reviews...
http://www.overclockers.co.uk/showproduct.php?prodid=GX-188-SP&tool=3
says
Also there are some minor problems with multidisplay (2 monitors), maybe a drivers error.
which was posted back in October!
i have that card and a sumsung 20" and my 26" tv connected, no problems in the slightest... the new 9.x drivers should be out soon anyway..
I have a 24" and a 19" using Xfire'd 4870 512mb and all is ok. Get a few crashes every now and then when I close lotro down but hopefully the 9.1's will sort that out.
I also use Ultramon which may or may not help.
On a side note how do you use multi clients with wow, do you mean you have more than one subscription.
