The New Cases Gallery
Nice to see a centurion on here every now and again, very decent cases for the money.
I've added a new gfx, but am planning some new case fans (sharkoon?) in my P182 with a fan controller, probably hold off the pics until this is all rebuilt and clean!
Here's my Lian-li, just replaced my old Akasa Eclipse 62 - nothing flash, just neat...Love this case
I swear our case is the same, but your motherboard is mounted the correct way round and mine is upside down..and I have to open the opposite side to access mine...
As for my rattling, I think its my Hard Drives or one of my case fans, but I don't really know how to silence them or where to get the correct rubber grommets for them!
If I compare my Antec 300 and Centurion for quality, Antec will be the winner, but if I go for component lining up and cable management – winner is Centurion 590.
Nice case.
Nanoman - damn that PC7+II is clean.... is it new or have you just spent hours cleaning it... Mine has never looked that shiny and how have you kept the finger prints off the silver alu?
You sir have a very tidy case. (mine fails now as I have 5x hard drives in it, there just isn't the room.
Very very tidy!
I have the same case but it has fingerprints over it and the cable managment is awful, how'd you hid the cables so good if you dont mind me asking? :)
Modular Power Supply for the win ;)
i used a holesaw and stuck most of the cables behind the side panel
He was talking about the lian pc7 from the previous page, not the antec 900 :rolleyes:
that pc25 looks awesome ;) my litttle brother is saving for one
only thing i fault with that case is you can't use the the DVD drive covers on them, but with door isn't a huge issue.
how is the air cooling? ie the front air intake with door closed?
Actually I was getting a bit annoyed with my core i7 heating a lot during prime but after cleaning the dust filters, my temps have gone down quite a lot, so on the whole it's actually quite decent as long as the filters get cleaned regularly. It's not the best cooling on the market but it's decent, especially considering it was the only mid sized lian li with 2 intake fans I could find...you pay for the looks though!
Forgot to say thanks :D I love this case!
same for me , i clean the filters 1 a month
PS my Lian li is mid size and has 2 air intakes ;) 1 in front and 1 in rear (although I have seen many use that incorectly as an exhaust, the side panel fan is the exhaust , actually when used correctly the temps are fine)
