- 22 Jun 2005
- England
My current setup which ive added to and changed apart from the cpu, mobo, case and powersupply
amd x2 4400
250gb hd
4gb ddr 400 (currently set at 333mhz otherwise mobo dies)
asus nforce 4 sli mobo
ati 4850 512
antec neopower 480watts (not sure if thats still sufficient these days?)
case lian li pc7 i think
i basically want to change the mobo cpu and ram for purely gaming purposes
if you can help me spec this it will be much appreciated. i would like to spend less then 400 but can go over if necessary.
I would like the motherboard to be crossfire and one which will hopefully last a few years and the socket isnt soon to be replaced
cpu and ram dont have to be top of the range if it puts up the price too much but would prefer 4gb at least ram wise.
and lastly looking at my system is it worth the upgrade? oh and thanks for the help ive been out the loop for a bit
amd x2 4400
250gb hd
ati 4850 512
