- 22 Aug 2005
- Clydebank
Hi all I made a quick batch to solve a prob that's been bugging me for ages..
Uploading a pic to my ftp and doing the URL for pasting into these forums, for example. This script will resize to 800 px in long dimension if you have imagemagick installed. (you should!, if not download it) otherwise just rem the 2 lines noted.
2 Batch files, required place them both in your %path% and put a send to in your menu to the first one.
Obviously there are a whole bunch of improvements and features could be added but this saves me the hassle of logging into to ftp each time an remebering my password, and then the url etc....
Man, took me longer to write this post than it did the script...
Sample out put
upload_img.bat
ftp_img.bat
Sample out put
Code:
Processing "C:\Documents and Settings\user\Desktop\20090125\DSC_1076.JPG"
ftp> open upload.ntlworld.com
Connected to upload.ntlworld.com.
220-
220-##################################################################
220-
220- Welcome to upload.ntlworld.com
220-
220-
220 upload.ntlworld.com FTP server ready
User (upload.ntlworld.com:(none)):
331 Password required for k.malone97.
230 User k.malone97 logged in.
ftp> !:--- FTP commands below here ---
ftp> mkdir test
550 test: File exists
ftp> cd test
250 CWD command successful.
ftp> binary
200 Type set to I.
ftp> put "C:\Documents and Settings\user\Desktop\20090125\\DSC_1076_resized.JP
200 PORT command successful.
150 Opening BINARY mode data connection for DSC_1076_resized.JPG.
226 Transfer complete.
ftp: 247244 bytes sent in 8.59Seconds 28.77Kbytes/sec.
ftp> disconnect
221 Goodbye.
ftp> bye
URL
http://homepage.ntlworld.com/k.malone97/test/DSC_1076_resized.JPG
VBULLITEN
[IMG]http://homepage.ntlworld.com/k.malone97/test/DSC_1076_resized.JPG[/IMG ]
upload_img.bat
Code:
@echo off
REM Image File Upload Script
REM Resizes supplied image file and uploads file to FTP Server and provides
REM URL of uploaded file and Vbulliten output for copy pasting...
REM Expects image as %1
set size=800
SET subfolder=test
ECHO Processing %1
SET img_name="%~1"
REM these next 2 lines if no resize needed
convert %1 -resize %size% "%~dp1\%~n1_resized%~x1"
SET img_name="%~dp1\%~n1_resized%~x1"
CALL ftp_img.bat %subfolder% %img_name%
echo URL
echo http://homepage.ntlworld.com/k.malone97/%subfolder%/%~n1_resized%~x1
REM OR THIS IF no resize. make similar mod below
REM echo http://homepage.ntlworld.com/k.malone97/%subfolder%/%~nx1
echo VBULLITEN
echo [ IMG]http://homepage.ntlworld.com/k.malone97/%subfolder%/%~n1_resized%~x1[/IMG]
PAUSE
ftp_img.bat
Code:
;@echo off
;(for /f "usebackq delims=" %%A in ("%~f0") do call echo.%%A)>"%temp%\%~n0.ftp"
;ftp -i -s:"%temp%\%~n0.ftp"
;GOTO:EOF
[B]user[/B]
[B]password[/B]
mkdir %1
cd %1
binary
put %2
disconnect
bye
